toy720
- July 8, 2005
- fort worth tx
- 2002 Exp 4x4 5r55w 4.0l
ok i want to see if anyone will concur with this theory i posted a while back
that i had 1-2 flare would shift at about 3000 rpm all other gears no problem
well i climbed uderneath and found that the intermediate band locknut had come loose i adjusted and no problems until now same symptoms big flare
or delay between 1-2 at about 3000 rpms let off the gas a little and it will
hit second i climed back underneath the locknut was not loose this time so
what im thinking is that this band is being worn severly so i adjusted it in a little with some improvement but would have to adjust in some more to clear up problem but i dont want to go to tight i dont want to start eating a drum.
does anyone have the band adjustment specs on the 4r55e i think it is
120in lbs back out 2 turns the problem is i have to screw the adjuster in quite a bit before i feel any resistance? i did not replace the bands when i rebuilt it
(shoot me now) but they looked like they had some life on them also forgot to note the direction when i removed them and i may have this band in there
the opposite direction it was in there which i believe would lead to quick failure ???????????? sorry so long any ideas
