act
- March 4, 2006
- PARIS
- 1996&1998
Hello,
I have a ford explorer 1996 4.0L. I have lots's of probleme whith my trans.
The car works fine when then engine is cold, after when the trans is hot,I have some troubles whith the transmission ( slow engagement in front,in 4 gear).
I found out some codes: P0751 & P0756.
So I change the both solenoides & I rebuild all my trans ( I've done it more 10 times for other trans whitout probleme).
After refix the trans,I've the same probleme whith the same code.
So I was disapointed and I rebuild the trans for the second time ( every time whith a new rebuild kit from transtar).
The same trouble again, so I make the job again for the 3 times, and I have the same troubles & the same codes.
I have check my harness, I've change my PCM.
I am going to be crazy about this , Please HELP ME.
Thanks.
Thanks.
