4R70W Transmission shudder | Ford Explorer Forums
JCat
Atlanta
98 Mountaineer
170,000 miles AWD
Shudders when shifting up into overdrive (4th)
Replaced the valve body
Flushed the fluid with Mercon V three times (completely)
Tried friction modifier . . . it helped briefly
What would you do next?
1. Replace transmission and torque converter with rebuilt and new ?
2. Replace the torque converter ?
3. Live with it (deactivate the overdrive with the button on the gear shift)
4. Sell the vehicle, its a downhill slope from here.
5. or ???????
If it was the TC, it would do it on all the gears. It might be worn band?
The description points to a worn converter clutch, the briefly improvement by using a friction modifier (shudder fix?) as well.
I would replace the TC
