dave_1998
- February 7, 2003
- Rolling Meadows, IL
- 98 XLT
I have a 98 XLT 4.0 SOHC 4WD with the towing package. Last night I was pulling my boat out of the water and used 4DW Low. It switched in OK. After I pulled out about 30ft. I put the trans in N and switched the 4WD to Auto. No click click … like I usually get. Then the dash light starts flashing both the 4WD High and 4WD Low lights about a second between flashes. The trans was stuck in 4WD Low. I checked all the obvious fuses and none were blown but some looked tarnished on the leads. Since I was in the middle of nowhere I drove to a gas station about 10mi. going 35mph. Then I notice that my turn indicators and emergency flashers don’t work. WTF. When I got to the gas station for lack of anything better to try I pulled out and checked every fuse. None were blown but many had the tarnish on the leads. I turn the car on with the trans in N and the 4WD turns off.
The turn indicators and emergency flashers still don’t work but the trans is back. So I start driving home and about 20min into the ride the turn indicators start working and then about 10 later the flasher turn on ( I left the switch on by accident). Are these symptoms related? The manual I have does not show the wiring diagram for the 4WD. I am going to replace all the fuses, anything else I should do?
