persalls
- January 4, 2003
- Vellinge, Sweden;Europe
- 2003 sport trac xlt
Hi guys!
Just bought the truck and getting to know fault´s and features
When switching the knob between different drive type´s it engages 4wd low and the light comes on. When switching to 4wd high i can hear the relay-box, behind the glovebox, switch but the control-light will not come on. Iám actually, so far, unsure of the the actual engagement of the system but i will try to lift the truck or even perform a test when I find a spot suitable for testing but could it be as easy as a bulb that went out? I have read about vaccum-testing and stuff but better to start in the easy-end?
What is noticable is that low engages but is 4wd actually goes in even in "low" needs to be further examined.
When I turn on the ignition the 4wd low light comes on as to check it´s functionality but the 4wd high does not, how is it in your trucks? this could be a first check I imagine.
//brg Per from Sweden
