Buckshot
- August 14, 2004
- Indianapolis, IN
- '97 XLT
I never post in 911, but I figured I'd ask in case I'm going to damage my front end worse than the 35s are already doing.
Went wheeling this weekend. Lots of sandy creekbottoms and water. Pics later - including a 30ft roostertail of water....Have had to take apart a lot of stuff to clean out the sand. I'll be asking about my interior fan for the AC/Heat soon too....blowing sand in car and making horrible noise like intakes are plugged or motor is being resisted. But my real problem at the moment I think is that 4wd won't disengage.
I completed the brown wire mod a while back and have been using it with a great deal of success. So I go wheeling, connect my brown wire, drop into 4lo and had a great time. After getting back out of the muck and dropping back to Auto, I still get serious binding and poping from the front end when turning. So much so that I can barely overpower it to continue any forward motion. Feels worse than just 4wd on dry pavement, but I haven't done it before with these 35s on, so maybe that will be normal.
With it in Auto and both with the brown wire connected and with it disconnected, I've backed up, gone back and forth from P, D, to N and back, driven 30 miles or so, and used a mallet on the Tcase shift motor. No joy. I just put all four wheels in the air on jackstands and confirmed that my front is still engaged...even with the brown wire disconnected.
1. Everything points to tcase itself since the brown wire should eliminate tcase shift motor issues, right?
2. I'll be doing a Tcase fluid change this weekend, but is there anything else I can use to narrow down possible issues?
3. How long would you drive in this condition on dry pavement before resolving it? Its my DD, so I'd like to keep driving unless I'm doing more damage.
Thanks in advance for the help.
