4wd to 2wd???? | Ford Explorer Forums
4wd to 2wd????
Derrick C.
Moderator Drinkin Corona
Moderator Emeritus
Twin Falls, Idaho---------B.F.E.
91 XLT, 92 XL
This is for my brother-in-law.
He also has a 92 Explorer 4x4. He wants to know if the mounting points for the I-beams and such are the same on both 2wd X's and 4wd X's. Hope you guys can help cause I wasn't sure.
Another one? Yep it's all bolt on.
The pivot points are not the same for the passenger side beam. The frames have the same bolt holes, but you would have to channge the bracket.
Where are you located? I'm actually considering converting mine to 4wd, maybe we can do some trading, for parts. I have all the parts you need to convert yours to 2wd & you have all the parts I need to convert to 4wd......Let me know
I also have some Superlift extended radius arms to add some insentive.........
