4x4 explorer front end conversion | Ford Explorer Forums
brett0991
so as of now i have a 1992 ford explorer and i want to replace the front end diff/ i beams with a solid axel. i want to go used and modify the gears and axels myself. what would be the best vehicle to do the swap from. i want something that takes little motifacations. any help would be much appreciated. thank you.
read the SAS section. that should answer your question and give you plenty of ideas.
3rd that. Foxracin has the best SAS "on the cheap" build thread I have seen. So envious.
