4X4 Front Wheel Bearings? How Big A Job? | Ford Explorer Forums
DoOver
Catskill Mountains Of New York
95 Loaded Long Wagon E4WD
I got a bad front wheel bearing on my 95 4X4 Aerostar. It is a single bearing type like on many front wheel drive cars. I did a bearing press-in on a 95 Saturn. It wasn't that bad. I called the NAPA guy and he said that this is a three bolt hub assembly. He says it's bolted on not pressed in. Has anyone here done this job? Do I have to take the spindle out via the ball joints? I'm trying to figure out if I should do this job my self or send it out. Thanks.
Brian
This is what my Ford software says:
Hub and bearing assembly.
Removal & installation:
1. NOTE: The hub and bearing assembly is not serviceable. If the bearing requires replacement, replace as an assembly.
Raise vehicle on a hoist and position suitable safety stands under vehicle. Remove wheel and tire assembly. Refer to «Section 04-04».
2. Remove disc brake caliper (2B120) and rotor. Refer to «Section 06-03».
3. Remove the three bolts retaining the hub assembly to the steering knuckle.
4. Remove the hub assembly.
For installation, follow the removal procedure in the reverse order.
Brooklyn bay rocks!
Thanks Brooklyn. Thats what I needed. One problem is, the drawing is not showing the axel that drives the hub assembly. I need to know what the torque is on the axel bolt?
My NAPA guy lists two hubs assemblys. One is $105 and the other is $150. Anyone know if the more expensive one is worth the extra $50? Things are tight here in the mountains. Thanks.
Brian
Holy Cow. That's tight. Thanks again BrooklynBay. Looks like an easy job. I'll report back upon completion.
Brian
I got the tools but I got a Brownie. So negitive on the pictorial documentation.
Done! I installed the hub assembly today, not really hard. I bought a China one from Advanced for $52.00 with tax. I got prices for a Timkin hub for as high as $180.00. I was just afraid that the high price one wouldn't be made here anyways, not sure though. You are going to need an axel nut socket and a 13 MM 12 point wrench or socket. Loosen the axel nut before you jack up the van. Jack up the van and take off the wheel. Drive out the brake caliper pins and hang the caliper up with a peice of wire. Now remove the axel nut. With new or really good 12 point 13 mm socket loosen the three bolts that run through the spindle, from the engine side, that attaches the hub to the spindle. I stripped one of the bolts because my van is old and rusty and so are my tools. I used a 12 point 1/2" drive 1/2" socket and used a hammer to drive it on to the bolt. I also sprayed the bolts with loosening juice. Take the bolts out. Now I had to drive the old hub out with a screw driver and a hammer from the engine side. Don't try to seperate the hub assembly from the spindle by driving a screw driver between them, as there is a metal spacer/gasket there, that I reused. Once everything is apart, I coated the axel splines with a little grease and reassemlbed. The Chinese crap hub went on with alot of play. I don't have a torque wrench so I tightened the axel bolt wicked tight. And thats it. I'm sure if one can change oil and a filter that you to can do this job. A real mechanic would tell you to change these in pairs. And this is a great time to change the front pads if you need to. Good luck. Stay safe.
Brian
Brian
Thanks for the update! How long is the warranty on the hub? Is the part number the same for both sides? You might have to replace the other side eventually since it probably has a similar amount of wear.
There wasn't any paper work with the hub, so I think it's cash n carry. They didn't ask "which side" when I bought so it I think both sides are the same.
Brian
Brooklyns right again.
Drivers side soiled the bed. But it took the inside of an almost new tire on it's way out. Rats. One pointer I would like to add. When you loosen the three bolts that hold in the hub don't remove them. Put an old socket over a bolt and use a hammer to drive the hub out. Take a few shots and move to the next bolt. The old socket is so you don't peen over the bolt.
Brian
