4x4 High Light Blinking | Ford Explorer Forums
danhenry
Ohio
2004 Explorer xls,4.6L
Hi,
The 4x4 auto high light is blinking. I've replaced the rear speed sensor on the differential, (Ford part) still blinking. What is next? Also, what is the potential problem if I just ignore it and let it blink? Can the brakes possibly malfunction or lock?
Thanks!
Welcome aboard!! :salute:
When I had the blinking 4x4 light and non working 4x4, it turned out to be a bad ground on the transfer case shift motor.
Worth a look.
Good luck and be sure to keep us posted. :D:thumbsup:
Thanks Rondo,
I'll check that out!
It's worth a shot. Doesn't cost anything to look.
Hope you get it sorted.
Hey Big Rondo,
After replacing the abs sensor in the differential with no luck, I finally found time ( a month later!) to get under the Explorer again and check the actuator wiring as you suggested. I found the ground wire completely broken off. Repaired and all is good! Can't thank you enough! Great tip and I really appreciate your taking time to reply! Thanks again and have a Merry Christmas!
You are very welcome. Nice job getting it sorted.
Merry Christmas & Happy New Year to you as well. :D
