Mamba42
- July 26, 2013
- Salt Lake City, Utah
- 2002 Ford Explorer 4.6 V8
Hello all, I have perused this site for quite a while and gleaned quite a bit of information from it, so thank you all for that. However, I have run into an issue that I am not able to solve with the threads that already exist on this topic.
Here is my situation: A few weeks ago I was driving home from Idaho and my 4x4 High light started flashing at me (I do not have a check engine light nor ABS lights). My 4x4 low still engages, but when there seems to be no difference between 4x4 high and 4x4 automatic (although the light does not flash when I press 4x4 high, it only stays on 4x4 high without flashing). Shortly after I got home I got onto this website and looked at possible answers. The first thing I did was check my fuses, and they are all good. Then, I ordered a new 4x4 Control Module (made sure it is the one for my VIN), and thought that would fix the problem... No luck, unfortunately. I then checked the ground wire on the transfer case shift motor, and it is in good condition, as is the shift motor itself. I then thought I'd replace the speed sensors on the transmission. To be safe, I decided to change all three (the TSS, ISS, and the OSS (although not the two rear OSS sensors located on the back of the transfer case). Changing the speed sensors did not fix the 4x4 high light flashing, but it did fix my transmission shifting issue which I was going to fix anyway.
Having tried all of these things, I am not sure what to try next. If anybody has a suggestion, I'd be glad to hear about it!
Thanks in advance!
Thanks in advance!
