Doomstang
- February 12, 2011
- St. Louis, MO
- 02 XLT and '91 XLT
Ok so I have an '02 with the auto 4x4. I have some ramps in my garage that I use to pull my vehicles up on to do various work. With rear wheel drive vehicles, the ramps slide across the smooth floor if I try to put the front wheels up on them. I have a '91 Explorer so when I want to work on that I simply put it in 4x4 and creep right up the ramps without pushing/sliding them across the garage.
The problem is with my '02. When I try to pull the front tires up onto the ramps it always pushes them across the floor. I've tried auto 4x4, 4x4 High, and 4x4 Low and it always pushes them. I thought there was a problem with the 4 wheel drive so I put it up in the air completely (on jack stands) and all 4 tires turned when I pressed the gas. Also, I know the 4x4 is working because we've had some good snow this winter (one was about 20 inches) and I was nearly stuck several times in the parking lot but was eventually able to get out (would have been impossible in 2 wheel).
So basically I'm asking why doesn't my '02 Explorer pull itself up onto the ramps in the garage when in 4 wheel like my '91 does?
