Dave85zxt
- June 2, 2001
- West Bend, Wi
- '97 4.0 SOHC Control Trac
I'll start off with a little history. My 97 4.0 SOHC control-trac has been experiencing a 4x4 bug. At first it showed up through the 4x4 only working when the truck was cold. After the truck would warm up, it would no longer work. I bought a service manual and followed the pinpoint test in order to identify the problem. Here is a short list of what I tested and the results:
- The brown wire that activates the clutch was reading only 4.5V when the selector switch was set to 4x4. (its supposed to read 12V according to the manual)
- The 4x4 and 4x4 Low lights work properly. No flashing or other indications of a problem.
- The 4x4 low actuator motor works properly. It shifts the T-case into low but only 2wd.
- The solid state clutch relay checks out ok per the manual's method.
- There is 12V to the solid state clutch relay.
- There are no shorts in the brown wire that delivers power to the T-case clutch.
This all led me to the conclusion that the GEM is faulty (per the manual) so I replaced the GEM and the 4x4 still does not work properly. I am about to bring it into the dealer and just suck it up. I have a few questions before I take the leap.
1. Could a faulty vehicle speed sensor (used for the control-trac) cause the GEM to not engage the T-case clutch?
2. If I were to bypass the GEM to engage the cluch would it cause any damage? I am thinking about installing a switch and standard automotive relay to supply 12V directly to the brown wire that activates the clutch.
Thanks for the help.
