- February 3, 2007
- Oakland, CA
- '00 Mountaineer
Last week when i washed my truck i sprayed the undercarriage down for the hell of it and noticed that the water runoff was a greenish tint just like coolant. I checked fluid in the overflow and it is ok. That triggered the memory of the "sweet" smell i smelled when getting out of the car after driving it. I had never really paid much attention to it before that, although it was noticeable--i thought it was related to the exhaust manifolds which quite possibly are leaking a bit. But now that i notice it, it is a very strong smell even after just moving the car from the driveway to the street. I looked under the hood for any sign of a leak, couldn't find anything. Under the car i see it looks like there's a leak coming from the front of the bellhousing/back of oil pan, but don't know why there would be coolant on the bellhousing, so i'm presuming that's just a little ATF. I also noticed what looks to be a small leak from one bolt of the oil pan, but again i'm not sure if that's just a little oil. I was looking for a leak in a line but couldn't find any. I sprayed water all around the area and the greenish water is running off the primary cat, but i'm thinking that just might be because that is the lowest point under the car for water to run off of. I felt around and up between the oil pan and bellhousing, and what gunk i got on my fingers did not smell sweet at all.
The car's never overheated, never even gotten hotter than normal according to the gauge. And it runs as if everything's normal. Any ideas? I've tried researching on here, i've read about thermostat needing replacement, waterpump gasket, and what i dread the most-a head gasket, but i'm pretty sure it's not any of those. Please, give me some good news, i can't afford bad news.
EDIT: I've also heard about doing a pressure test, I'm not sure what's involved in that though or if anyone thinks i need to do that. My roommate suggested removing the oil pan and seeing if there's coolant in there, but i just got an oil change a couple hundred miles ago at most, and mechanics didn't say anything. Also, i'm close to hitting 100k miles, at which i was going to replace plugs and wires. I think i've heard something about checking the plugs in a situation like this??
On another note, i think my tranny is slipping/flaring/whatever from 1st-2nd/2nd-1st, could an ATF leak lead me to the cause of that problem? I haven't really looked into that yet.
