5.0 harmonic balancer removal | Ford Explorer Forums
SaleenJOE
Wichita KS
99 Saleen XP8
Anyone know fo a write up for removing the stock balancer?
Joe
Use an impact gun to remove the bolt and use a harmonic balencer puller or modify a steering wheel puller and you should be good to go.
K thanks. Does the radiator need to come out or just the fan and shroud?
Depends on how much room is on the 5.0. I have the 4.0 and I think I need to remove the fan and shroud on mine so I would assume you need to do so on the 5.0. Make sure you get a fan clutch removal tool.
