jkgibson
- August 8, 2007
- Chapel Hill, NC
- '97 Explorer Sport
Hi All. New member (Jim) at my wits end.
My wife's '97 Explorer Sport with 2wd and 5 speed transmission does not want to shift. It's acting like a clutch pressure plate that does not want to release the disk in that it's very difficult to shift from neutral to any gear and even between gears when driving down the road, although it is a bit easier then. Very occasionally it shifts like it should, nice and easy.
I replaced the clutch with factory parts, including the pilot bearing and slave cylinder/throwout bearing. While in there the flywheel was properly resurfaced and I sent the trans off to have it checked and outside of normal synchro wear it seems fine. The three rubber plugs up by the shifter are fine and the trans shows no signs of leaking.
Since then I have noticed no difference in shifting performance and have gone so far as to replace the clutch master cylinder and bleed and bleed and bleed the system, all to no avail.
Help!
Jim
Help!
Jim
