kjgces
- March 27, 2009
- bethlehem,pa
- 98 explorer 4.0 sohc 4wd
many of you have seen my previous posts, so you know i have been working on this beast for a while. well, after another long night under the truck, this is where i am. i now have no reverse and it wont shift up into third . it will drive in manual 1 and 2, i have done pressure readings and they are ALL low. i have rebuilt the valve body, installed a superior shift kit, installed an external filter, cleaned the radiator cooler and the external cooler with kooler kleen. i have installed a BRAND new EPC. no codes(that my reader will read). no blinking od light. have engine braking. bonded gaskets. ford blowoff valve. replaced servos and springs. i can drop the pan in my SLEEP. OK, you also know i'm an engineer and I DO NOT believe that all engineers are right all the time, if they were we would need this forum. I have searched high and low to find a full diagram and logic of this stupid computer and transmission. none found that link everything together, only bits and pieces. NOW, what do i do. I have even lost 912.00 to a scammer on ebay for a new transmission. right now there is only one thing i can think of. ASSUMING there is a "connection" (either hydraulic or logic)between reverse and third BEING shift solenoid two( the one next to the EPC) do you think SS2 could be "not turning on electrically. The solenoids are ALL normally open, so.. they vent the hydraulic pressure(fliud) out thru the center of the electric end of the valve. here is the idea. in the manual settings of gears, these solenoids "may" be used differently than when in the "drive" mode. I'm sure they are but again without a complete diagram we are guessing. IF it is not turning on it will blow off system pressure all the time, which i have. yes, i tested all the solenoids when the vb was out. all were fine with the electrical tests. no, i od not have a way to test it in operation. MAYBE the elctrical circuitry to CLOSE the solenoid and block the venting(which is what happens when it is energized ) is fault but how can you tell, this is so frustrating. please add any helpful comments. i have used up ALL my patience for the third time on this piece of junk. ask or comment anything, i will respond asap. thanks, kjgces.
