lifttruck2008
- May 24, 2008
- 2001 Sport Trac
I Just did a fluid mercon 5 and filter change on my dads 2001 ranger with the 5r55e(i think)4.0l 4x4. After I was done he asked me to adjust the bands. I have done this several times before on my 2001 sport trac with the 5r55e.
The nut and adjuster was pretty rusty so i sparyed them down with pb blaster and waited a few hours, tried it with no luck. The locknut and adjustor keep moving as one.
i wire brushed the exposed threads sprayed again. Nothing, so i used a map torch to heat them, i got like a 1/8 of a turn of movement then the square drive on the adjustor stud broke off At first i figured it was not enough movment to upset anything.
I was wrong, I took it for a test drive, O/D light is flashing lots of clunking and cannot manually shift into 1st or 2nd. As far as I know the adustor is installed from inside of the trans?
My plan is to go to a a trans shop tomorrow and have them cut off the lock nut and put a new one on. then weld a new nut on the adjustment stud and have them adjust the bands. How does this sound, its needs to be done asap, does anyone have any better ideas? thanks in advance.
