TECH SUPP
- April 28, 2010
- 99 Eddie Bauer
Hello Everyone!
I have read posts from this site before but have posted so here it goes.
I had the problems with the OD blinking and getting an PO741 code after a few miles down the road then I came to a stop and no forward or reverse. I replaced the fluid, filter, valve body and solenoids with a supposed to be rebuilt/updated Ford unit from ebay which looked to be accurate. I have forward and reverse but still get the blinking & code PO741.
I was going to adjust the bands and see if my problems were any better after checking electrical connections.
Problem: The lock nut on the forward band only backed off maybe a turn (very hard to turn) will now not turn in or out without a great degree of difficulty and starting to bend/round the stud end. I now have no way to know exactly how far this has moved due to my alignment marks are gone on the stud. I am afraid to completly remove the stud from the trans to replace this nut with a vice due to the band tensioner falling out of alignment.
Question: Will full removal of the forward band adjustment stud cause problems replacing while trans is in the truck with pan and all installed on reassembly?
Help!
Help!
