There is no kick down cable. The gear selection is controlled electronically by the PCM. The only mechanical control for the trans is the shifter cable which is attached to the DTR sensor. The DTR (digital transmission range) sensor sends a signal to the PCM to tell it which mode (P,R,N,D,2,1) you have selected. There is also a mechanical link to engage the parking pawl when in P.
