heiseman
- March 6, 2006
- Edmond, Oklahoma
- '91XLT
NO GO---After pressing hard enough to down shift at 40mph with the selector in OD the trans will not engage any gear unless I push in on the kick down cable manually. When I can get it to seleca a gear it seams to work OK if I do not select the OD position. If OD is selected there is a little indication of movement if on flat ground as the engine is reved. When I retunt to the P position, manually push on the kick down cable, then select R,1,2 or D, it will select the gear most of the time. Is there a quick fix or is something in the VB need attention. This is a one owner 173,000mi Explorer that was not driven hard, the previous said he probably didn't activate kick down more than 6 or 8 taimes in all the years he drove it.
I can usually fix most problems I just need guidance.....New owner HELP needed!!!!
