Grant S
- August 24, 2016
- Bellevue MI
- 2003 Explorer Xlt 4.6 4x4
I recently purchased a wrecked 2005 Explorer with a fairly newly rebuilt transmission to swap into a 2005 Mountaineer I also just recently purchased. The Mountaineer would only move in 3rd gear, the previous owner had tried swapping out the solenoid pack trying to fix it with no success. Unfortunately the Explorer was not drive-able when I bought it so it was a gamble on the tranny being good, although I was shown paperwork for the transmission rebuild within the last 20K miles. So I swapped that tranny into the Mountaineer over the last couple of days (both had the exact same code on the I.D. plate) but now I have run into a problem I am hoping someone on here has seen before. I changed the filter and set the fluid level to a quick drip/not quite a stream coming out when running in park. The issue I am having is the engine must be rev'd up to 1500 rpm, and then its takes 1-2 seconds before the transmission will engage in any gear (RD321). I have not taken it out onto the road yet (just gone up and down driveway) to see if it will shift through the gears or not. There is no check engine light or flashing O/D light. Any ideas?
