60-65 shimmy/vibration | Ford Explorer Forums
husky_00
I have the same 60-65 mph vibration heard about frequently on the web. I've spent a fair amount of time playing with it and although I haven't fully tested my theory, I have one which the evidence supports.
Those of you who took (and remember) physics or dynamic control, will appreciate this. Any mass (weight) connected to a spring with minimal damping (underdamped system) will have a natural frequency and is governed (in a truely linear system) by the relation f=sqrt(k/m), where k is the spring rate and m is the mass. If set in motion it will continue to vibrate at that frequency until the energy is damped out of it by friction. Also this system can be induced to vibrate at a significant magnitude with only the slightest vibration driving it (a seperate source of vibration connected to the spring/mass in some way).
The motor/transmission is a mass and the rubber motor mounts are a effectively a spring (although not quite a linear system). It will have some kind of a natural frequency associated with it. Any tire imbalance or out of round at the right speed would become a driving vibration at the right speed. For stock tires (roughly 28.8" dia by the math, I haven't measured one) it apparently happens at 65 mph or 12.61 Hz. For 31' it would happen at 70 mph and for 33's it would happen at 74 mph. Does anyone have large (or small) tires and can verify this?
One of the things I've done to test this, is chain the motor to the frame, effectively increasing the spring rate and thus the vibration frequency. I didn't do a good enough job, because the chains went straight up and down allowing vibration side to side. The effect was that it changed the direction of vibration and could definately be felt. The whole dash shimmied side to side at speed. This adds credence to my theory that the motor is resonating and not some suspension component.
I also changed my motor mounts to something that felt a little stiffer. The frequency went up a little. I also notice that on cold days, it doesn't do it till the truck gets well warmed up.
The problem is wearing on me so I'll likely tinker some more in the near future. In the mean time I'd be interested to hear anything that has bearing on my theory.
Ever get anywhere with this?
I know this was a long time ago.
Now that I have my lift on and 31's, I have a nasty vertical vibration that starts at 70mph, which adds credibility to your theory. It's not a shimmy. I don't feel much in the wheel at all. It's definitely mostly up and down under my feet. I thought maybe it was because the suspension was now too stiff to react to the smaller bumps and so it caused a vertical chatter. But, what you talk about makes sense.
Did you ever get anywhere with this?
Thanks.
I do have 225/70/15 (about 27") and I get the vibration around 60mph.
I would check the tire balancing
Thanks for the suggestion, but obviously that's the first thing I thought of. I've had the tires rebalanced at 2 different shops and it has made no difference. I've also the the wheels checked for straightness, and the wheels and tires checked for out of round. Not it either.
Weird... I had that 60-65mph shake syndrome but it all went away when I took the EX in for a 4 wheel balance and rotation.
--mark
I finally got the vibration to go away, but it was by skirting the real problem. I threw away the keystone steel wheels that were on it, as I found a set of alloys off a late model explorer. The alloys and new tires made all of the difference in the world. Its very smooth all the way up to as fast as I want to go anyway. As a side note, I did discover that the problem was very prevalent on the driver side front suspension.
