daddy_ja
- January 31, 2004
- glendale AZ
- 91 Explorer EB
i have a question for all of you suspension guru's out there. right now i am running a 6" sj class II lift with 97 2wd F-150 coil spacers up front. im still having some camber issues /-\. my question is do you think i will get and more lift out of putting just 8"sj coils in instead of the 6" coils w/ the spacers? and would the 8" coils AND the spacers be to much for the 6" brackets? if all else fails i know i can put camber bushings in, but i would like to see if i can get a slight bit more in the front and at the same time fix the camber issues. i still get a little rub every once in awhile on my 35's. thanks, Ja
