dioalp
- July 3, 2011
- dioalp@yahoo.com
- 1985 Bronco II
I'm new to this forum but not new to my B2 which I've owned for 10 yrs having bought it used with 84K miles. It's a 4x4 2.6l 5 speed now with 186k mi. Ok now the history:
Like many I continue to have challenges with the TFI and stator. I've replace both a couple times but they failed quickly until I discovered a ground missing. After fixing the ground issue it took about 2 months for it to quit for the 3rd time leaving me stranded, agin .... ug! While testing the wires for faults I discovered that the green (ground) wire leaving the coil started smoking. I turned off the ignition and discovered the wire going to one of the larger wire bundles had shorted or grounded on the pwr steering metalic hose connector and burned completely thru. This wire as it goes into the wire bundle has a 1/2" x 3" rectangular molded rubber block that has a capacitor on the inside. It's stamped with CRC 22k 5%FA5 on the cylinder. (I think this is a capacitor)
Now the question: This molded block melted the wire just outside the block and part way inside, preventing any repair. I opened the block to see if it could be fixed and attempting to solder a new lead to one end of the capacitor the wire end of the capacitor melted off..... dumb me... I should have used a heat sink!
What the heck does this capacitor do and can it be eliminated?
I believe at this time this item may be the reason why the TFI failed... again!
Thanks for any replys.... Dennis
