Doc Holiday
- September 18, 2007
- Nanaimo, British Columbia, Canada
- 86 4X4 XLT
86 Ranger 4x4 with 3 litre engine. Runs fine when engine is cold. When engine heats up is starts to mis-fire then after about 15 minute when engine is at full temperature, it w'ont run at all. Had it to a garage and they said the complete fuel system needs replacing - about $1000. Vehicle isn't worth that input. Fuel pressure is 35 psi when cold then falls to 5 pse about the time the engine is hot.
-Is the problem sludge in the tank as suggested by the garage? If so, is there any way to clean the tank without pulling it.
-Is is a weak fuel pump? If so, will an inline fuel pump suffice instead of replacing the in tank pump. Any recommendations?
Thanks for any help offered.
