dnoot
- September 23, 2006
- Sherwood Park, Alberta
- 1991 XLT 2WD
I'm new to this forum and have learned a lot. Have searched and seen similar issues posted, but not the same. Hoping someone can point me in the right direction. (I apologize for the long post - trying to provide details ;-)
For the last 1000 kms or so, I was getting the best mileage I've ever got, 3-4 MPG better than normal. Then from one day to the next, my '91 Explorer (2WD, auto, 230K kms) crapped out.
Here's what's happening:
Had it towed to my mechanic, but he had trouble reading the codes on two different devices. So I went over and tried to read the codes based on instructions posted here (jumped to ground and read CEL). Unfortunately, I didn't do the break pedal / steering wheel (?) / mash throttle during KOER, so what I got is not likely useful. (Can someone please point me to complete instructions, including timing of the user inputs, during KOER?)
KOEO
Some initial rapid flashes, then
--> 1-1-1, repeated
--> long break, 1, short break (not proper timing for separator?!?)
CM
If I assume the 1 above was the separator,
--> 2-3-2, repeated
If this is right, thorssell.net says "232 (M) EI primary coil circuit failure"
Some other on-line code lists do not include 232.
KOER (again, no user inputs)
flashed 1-1-1, then after a minute or so, tons of flashing all over, and the spacing didn't seem proper. I tried to grasp something: perhaps 1-5; 1-6; 1-7; 2-4.
Any ideas?
One other odd thing, likely unrelated: the +12V lead to charge the battery on a holiday trailer is not working properly (it was fine last season). Oddly, it reads 12V at the truck connector, but when I plug my trailer in, it drops to about 5V (even when reading on the trailer connector with the trailer +12 wire disconnected). Everything else is working fine (lights & trailer brakes). I've spent a fair amount of time tracing wiring, re-doing grounds, checking fuses, etc... all looks fine on both the truck & trailer.
Thanks in advance for any assistance!
Don
PS - just went through similar issues with my '90 Volvo 240DL although the rough running was intermittent. Turned out to be the ECU - diagnosed through a forum! Was cursing that car and pointing to my trusty Explorer as a great vehicle that's never let me down... DOH!
- starts OK, but the idle is really rough (like it's seriously missing)
- stalls after 10 - 20 seconds
- CEL comes on after a while, but doesn't stay on (i.e. it's off when I restart)
- throttle response is very poor - very difficult to get revs up
- smoothes out somewhat at higher rpm, but still rough and sounds like its "barking"
- no power - stalls as soon as I put it in gear (with throttle at idle or pressed a bit)
- rpm reading on tach *seems* low for the engine sound
- when revving up to 2000 rpm or so, occasionally the revs jump (and engine smoothes out) for a second, then reverts to crap
- unplugging MAF sensor makes no difference
- swapped MAF with another used unit - no difference
- my mechanic says it's running lean, but when I struggled to keep it going today, it smelled to me to be running rich
KOEO
--> 1-1-1, repeated
CM
--> 2-3-2, repeated
Any ideas?
Don
