wildstang said:
Rhett, it does start, but needs to crank over a lot more then my 92 ranger with a 4.0. That sea foam you mentioned, does that work good for cleaning injectors?
Well before the injectors I'd look into having the starter, battery, and alternator load tested. I'd also think about replacing the battery cables. All of that is cheap stuff and more commonly causes hard starting than the injectors.
Regarding Sea Foam, it works GREAT for cleaning injectors. Now keep in mind if your injectors are very badly clogged, then the best way to fix that is to pull the injectors and manually soak them. Or replace them.
Here's a good sea foam procedure for a 1st gen:
Do this in a well-ventilated area.
I'd recommend you go to a hardware store and buy a 2-foot long piece of clear plastic tubing, about 3/16" ? (not sure) inner diameter. The idea is to get a tube that will fit fairly tightly around your truck's throttle body vacuum port. Then get your bottle of sea foam. Get a cup or glass jar, and pour about half to 3/4 the can of sea foam into the glass jar.
Start the truck. Attach one end of the tubing to the vacuum port on the bottom of your throttle body (you will probably have to remove the intake tube to reach under there--but don't worry, the truck should not die when you do this. Keep the MAF and breather attached, just undo the intake tube from the throttle body to allow yourself room to access the vac port on the underside of the throttle body). If the tubing doesn't fit fairly tightly around the port, you need smaller tubing.
With engine running, BRIEFLY put the other end of the tubing in your jar of seafoam, then quickly pull it out. You don't want to flood the engine, just let it sip a little at a time. Work the throttle butterfly on the side of the throttle body to make sure the truck doesn't die while you are treating it.
Truck may smoke quite a bit. This is normal. Then again it may not smoke much at all. I've seen both.
Once it's sucked in all of the Sea Foam, shut down the truck. Re-attach the vac fitting, and re-attach the intake tube. Let truck sit for 10-15 minutes.
You can dump the remainder of the Sea Foam into your fuel tank (using a funnel for no mess).
Start the truck, and drive it BRISKLY for about 15 minutes or so. That means get on it. When you first get on it, after leaving your driveway, you may well see a big rooster-tail of smoke. This too is normal. I always take mine to the interstate and run up and down in "D" at about 80 mph. Cleans it out nicely.
Solves pinging problems, idle problems, restores pep. I have found that I need to do it about every 8000 miles.
