Dmixon850
- April 14, 2014
- Rocky Mount, NC
- 1991 Ford Explorer
I just got this '91 Explorer which is in great shape for it's age. It needs some little things done with it but it had the motor replaced two years ago and the transmission replaced a year ago. My problem is that when you shift it into gear, it is like it hits something hard, locks down and chokes the motor down and shuts off. It runs perfect in park or neutral. Pat the gas, fine. Idles fine. Now I had a mechanic come out to troubleshoot it and he thought it might have been the fuel filter. Replaced it (which it really needed) but it still does it. (Now if it sits a while, it will move about ten feet the first time you crank it an shift it into gear but then it stutters and locks down and shuts off.) So this mechanic jacks the rear end up and put it on jack stands. He turns the wheels and they are very hard to turn so he thinks maybe the brakes are locked up. He removes the wheel and drum, but the brake shoes are fine. He has me crank it up, put it into gear and it works just fine. Reverse-fine, drive-fine. So he put the drum back on, we do it again, it turns fine. So he put the tire on and we do it again, ok. He drops it on the ground and it moves ten feet and then locks up. He jacks it back up and when I shift it into gear, it's locked up.
Now, I have been told it could be the Air control sensor, the neutral safety switch or (this mechanic said) the rear end is shot. Any ideas? Any advice, suggestions or references would be GREATLY appreciated!!!
This is a 1991 Ford Explorer 4X4 4.0 V6 Automatic.
