Ranger Al
- December 1, 2004
- Fresno, California
- '00 FX4 Ranger
I am about to give up on this stupid thing, HELP!! The thing start out with bad Purge sensor at the canister. I tried cleaning it and doesn't clear the code, so I replaced with a new sensor. The code when away and about to test drive it. It spitted out a new code, faulty IAT (intake Air Temperture). Again, tried cleaning it and doesn't work. Replaced it and it goes away. I also check the MAF sensor and it is clean as well as the filter. I've also replaced the O2 sensor (I could only locate 1 on this vehicle). The Key On Engine Off (KOEO) Malfunction Indicator lamp is all cleared.
When I start the engine it would run smooth for a few seconds and the Check Engine Lamp would come on. This time it flashed code 998 which indicate "Hard fault present".
I am thinking of replacing new spark plugs and wires and hopes thats would solve it.
Anyone have suggest????? HELP, HELP, its my Inlaw and I am only trying to be the good son. Already, I think they are pissed off at me for working on it little as a time.
