91 transmission issues!!! | Ford Explorer Forums
fordex08
Huntsville,Alabama
91' Eddie B
i drive a 91 eddie bauer and it runs,drives good nice acelleration and everything,but for some reason when u punch it from about 40 and up it slips.
when you press the gas down to acceletate faster or quickly to pass someone for example it revs up the trans slips out of overdrive and rite after this happens the rpms drop back to normal and it slips back into overdrive like normal. it doesnt do this all the time and i know its overdrive cuz i can drive it in normal ''D'' without the overdrive and it never happens. So can anyone help me please??? or have any good ideas whats going on? id def like to get this fixed :D thanks!:p:
Adjust the bands, and the kickdown cable. Did you check the fluid level? Sometimes the servos dry out, and start to lose apply pressure. Did you see if there is any transmission fluid in the vacuum line going to the modulator?
