jeffpcell
- December 29, 2009
- Cleveland Wisconsin
- 91 Explorer XLT
Howdy, I've recently acquired a 91 Explorer XLT that has been sitting for about 9 months. The previous owner said that it needed a fuel pump and wanted it gone. After towing it home and doing some reaserch I dove head first into it, but now I'm coming up for air and looking for any advice available that will help me. I did get it to run one time, but i had to ground out the fuel pump test lead to do it. The fuel pump doesn't prime with the key on, nor does the check engine light come on. I checked out the relays, tried jumpering past them and still nothing. After consulting a chiltons and haynes manual I gained a decent understanding of the PCM and wiring harness (thanks in large part to members of this forum) Pin 20 is a good ground at all times, 40&60 on the other hand are grounded only with the key off, when you turn the key on 40&60 bring back 12 volts. My idea of the problem is that either a sensor has gone bad, shorting the +12V line to the ground or a wire in the main engine harness is doing the same. Does anyone have an idea on what might be a common failure in this cenario? I've done quite a bit of homework already, but a fresh perspective can always be a good thing. Thanks Ya'll!
