arquerogringo
- March 2, 2004
- San Carlos,Mexico
I had a soft brake pedal forever and the system was generally worn out so I replaced the:
pads shoes
resurfaced drums and rotors
hardware
calipers
wheel cylinders
master cylinder
The master cylinder was bench bled and the system was bled by bleeding the farthest wheel from the master cylinder first working to the closest.
I did this twice, the seconed in a troubleshooting effort. a couple of liters of brake fluid were used in all. There is no air.
The pedal is still soft. It brakes well but if I press with moderate force I can push it to the floor. There is no wall, and I want that wall.
Coould the booster be the problem, or could it be a bad new master cylinder?
Thanks,
Damon
pads shoes
hardware
calipers
wheel cylinders
master cylinder
Thanks,
Damon
