92 cupholder removal | Ford Explorer Forums
19Exploder92
freehold nj
92 4dr explorer
Hey,
I need a little help. I just got the dual cupholder out of a 93 and cant seem to get the old one out. It has the singal cupholder. I removed the four screw out of it which are in diffrent spots then the dual one and the front of it is stuck. There are no visable screws and such. If someone has any clue Please help me. Thanks
I did the same thing. Theres 2 screws in the coin change holder thing, then two more on the other corners under the plastic. You'll have to pry up the plastic to get to them.
Hey thanks for reply. I have the two screws out of the change part and still cant seem to get it to pry up to get to the other ones. I even have the whole console out now and cant see them from the bottom either. Let me knwo how you did it. thanks
If you see Crank's thread, you'll see where the 4 screws are. The older style (single cup holder) uses the same holes, so you can kind of figure where the screws are. I'll take a pic of mine really quick.
Here is the pic, it's a little blurry, but you can tell where they are, just really pry the plastic off.
I guess there is two other holes I forgot about in the bottom of the pocket, but you probably already saw those.
If anybody wants to give me a clear picture of the single cupholder holes, I will add that to my thread:)
Thanks alot I didnt realize that there was rubber around the cupholder like that those were the screws that I was missing. I took out the whole console thansk to crankcase helpful post but was upset to notice that I had actually pulled the stud out of the floor and hadnt broken the mount. I guess I'm going ot have to find someplace to weld in a new stud when it gets warmer. Thanks for your help.
:cool:
