gemini child
- December 5, 2004
- Ontario
- 1992 Eddie Bauer
Bought the truck, drove it home, shut it off infront of the garage. And that's where she lays.
It is definately NOT a starter or fuel related issue (checked both extensively.) The spark is very very weak. (it just cranks, no start)
Swapped ignition coil, crank sensor, and EEC (? not sure thats the right name for it. THe black box on the rad cradle, next to the passenger headlight with a 12 pin harness.) Changed to new plug wires and plugs, battery, battery posts, and various other positive wires. Remade grounds from battery to frame, frame to motor, motor to battery, and just to make sure I added a ground from the ignition coil bolt to my grounding point between the battery and motor. I measured 12.5 volts on the postive wire going to the ingintion coil and 1.5 ohms from the coil bolt to the battery post; so both are good.
Connected Snap-On scan tool, did a wiggle test and a crank test. Nothing significant showed. The scan tool gave me the diagram and measurements for the EEC and the measurements for all 12 pins. So far the only thing that I've found to be inaccurate is the negative ignition pin (pin 4 I believe); it's not showing a ground at all. (Used a DMM for all measurements). I also measured off to insure voltage was good at key cylinder, main harness, main fuse box, each fuse, relays below fuse box, and at the ignition coil. :fire:
Two days later, my conclusion is somehow, somewhere there must be a broken wire or bad conection in a plug. Likely between the EEC and the ignition coil, but no luck so far.
Does anyone know where or what my problem is, or have had this happen to them and could throw us a bone!?
