ohthathurts
- June 17, 2010
- Vancouver, Washington
- 1992 Explorer XLT manual
Hi this is my first post on the forums. I purchased my 1992 explorer XLT v6 pushrod about a month ago. It has a manual transmission and auto lock hubs. The vehicle only has 105k on it but good god the problems i am having. Heres my list of things i have replaced. AC compresor, starter, all 4 ball joints, both radius arm bushings, passenger front seat, drivers side door panel (still no handle), front disk and pads, front and rear wiper motors, master cylinder, high pressure line on the power steering, steering gearbox, and my ash tray
:. Now here is my list of problems left.... Rear drums need replacement, Valve cover gaskets are leaking, and lots of tranny work, gas gauge doesnt work, and my speedometer is about 5 miles off and bouncy at low speeds. The tranny is my big concern at the moment. I took it to a local transmission specialist and i was completely dry in fluid on my clutch and my tranny oil. They said i needed to do a clutch job a hydraslave, and the freeze plugs in the top cover. Here are the problems i am having so i can make sure of what i am doing before i go digging into it and f-in up. When completely stopped i hear what sounds like for lack of a better work spinning sound from in side the tranny i push the clutch in and it slowly fades away. Let the clutch out and it gets loud again. the sound does not go away while moving even with the clutch in. It gets louder as i am going down the road as well. Is there a Input shaft bearing? I have purchased a clutch kit and flywheel and a slave is on order i am picking it up tomorow. Is there anything else that i should do while i am in there. Will this fix the sound. Will it tighten up my shift stick which is very loose for 1st through 4th but 5th and reverse are normaly tight. Thank you for reading sorry for it being so long.
