mchammer
- December 21, 2001
- ontario Canada
- 93 4dr
my 93 (4.0L OHV) started runnig cold two years ago. I replaced the stat with an oem ,properly installed and bled.no help. Went to the dealer , payed some $ ,they did exactly the same thing. Still no heat. We get minus 35-40 degrees during the winter (thats C or F ) almost the same. The vehicle is almost undrivable. The temp guage slowly rises to the 'N' and then quickly drops to stone cold. A cooling system pressure check showed no leaks. Oil is clear. I changed the clutch fan. No help. The rad hoses feel warm and the temp gauge will creep up to the 'N' while sitting and idling , but as soon as you get air flow through the rad the heat is gone. Now I have the rad 80% covered for the winter but this only helps a little. Contacted the manufacturer for possible solution but never had a reply. Love the explorer , its a big improvement over the blazer just wish we could drive it all year. This XLT has 216k on it and otherwise runs great! Any ideas or suggestions would be greatly appreciated. Thanks
