stx4.0
- January 17, 2009
- ohio
- 94 sport
Im trying to figure out an issue I am having with my 94 explorer.It has a pretty good shake at idle and all through its running range like it is misfiring.I bought it this way and Immediately pulled the codes from the computer.All that came up was EGR and I replaced all the parts associated with it and that took care of the codes.I next did a compression test and all cylinders were 155-160 which I thought was great as it has 224,000 miles so i am confident the engine itself is fine.It already had a new coil pack and I replaced the plug wires (and made sure to put them back in the proper location).The only things I can think of now is the fuel pressure regulator and fuel injectors but I could be missing something else?I did check all the vacuum hoses and they are fine.Any one got any ideas on where else to look?I really wanted to look at everything I can before messing with the fuel injectors since this thing has the egr setup and is a little more involved when pulling the upper intake.
