The only information I can find on a 1994 explorer anti-theft device is how to install one. Other then that I will look in the back where the 4wd control module is located. I will also look into the factory radio amplifier while I am back there digging around. maybe I'll actually be able to write a how to and not copy and paste one
1994 Ford Explorer Car Alarm Installation Guide
Whether your an expert Ford Explorer car alarm installer, Ford Explorer performance fan or a novice Ford Explorer enthusiast with a 1994 Ford Explorer, a Ford Explorer car alarm wiring diagram can save yourself a lot of time. One of the most time consuming tasks with installing an after market car alarm, car security, car remote start, automatic remote starter, shock sensor, tilt sensor, car alarm sensor or any auto alarm is identifying the correct color car security wires for a 1994 Ford Explorer.
Use of the wiring information is at your own risk. Always verify all wires, wire colors and diagrams before applying any information found here to your 1994 Ford Explorer.
Questions
If you have any questions pertaining to the car wiring in a 1994 Ford Explorer , please feel free to post it at the bottom of this page and either we’ll do our best to find you the information you need or hopefully someone in the explorer forum community will have the information you’re looking for.
Battery Constant 12v+ Positive Wire (+): Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Red/Light Blue
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red/Light Green
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Green
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: At Headlight Switch Or In Fuse Box
Power Door Lock Negative Wire (-): Pink/Yellow (5 Wire Reverse Polarity). Vehicles with keyless entry are negative (-), vehicles without keyless entry are 5 wire reverse polarity. Vehicles with the key pad on the door are considered to have keyless entry.
Power Door Lock Negative Wire Location: In Drivers Kick Panel
Power Door Unlock Negative Wire (-): Pink/Light Green (5 Wire Reverse Polarity). Vehicles with keyless entry are negative (-), vehicles without keyless entry are 5 wire reverse polarity. Vehicles with the key pad on the door are considered to have keyless entry.
Power Door Unlock Negative Wire Location: In Drivers Kick Panel
Door Trigger Positive Wire (+): Black/Light Blue
Door Trigger Positive Wire Location: At Under Dash Light
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Yellow/Light Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Gray/Orange
Tachometer Wire Negative Wire Location: At ECM, In The Passenger Kick Panel
Brake Light Positive Wire (+): Light Green
Brake Light Positive Wire Location: Switch On Brake Pedal Bracket
Factory Alarm Disarm Wire (-): Dark Green/Purple
Factory Alarm Disarm Wire Location: In Drivers Kick Panel
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
http://www.modifiedlife.com/1994-ford-explorer-car-alarm-installation-guide/
Maybe I'll install one after I get the things that NEED fixed, fixed.
I wonder if I unhook the factory disarm wire if it will kill my haunted anti-theft system? Will try it tomorrow and update this post.
