Yusuke620
- November 6, 2012
- St.Louis
- 1994 Ford Explorer
I have been a Mechanic for close to 20 years and am currently a Car Audio installer at Custom Sounds in St. Louis.
Here's my problem. My 94 has always had a problem with voltage drop, i owned it for 2 years before i ever put a stereo system in it.
Every time i turn on the headlights, wipers, blower motor the voltage meter drops. with each accessory i use it drops a little more.
Today i replaced my battery to engine ground with 0 gauge wire, the starter to solenoid wire with 0 gauge and the body ground to battery with 4 gauge.
All my factory wire was corroded all the way through.
At night with the lights on and blower i cant listen to the stereo at the volume i would like, lights dim and battery meter fluctuates really bad.
I have a 4 channel and 1000 watt mono block amp. 5 farad cap, 4 gauge wire running throughout.
I know the stereo has nothing to do with the voltage dropping, it doesn't help
but the problem was there long before the system was installed.
Long story short, after upgrading the wire that i did my dash lights and head lights are quite a bit brighter but the voltage drop is still there.
Anyone had this problem and know what i need to do to fix it?
Thanks in advance, if you have any audio questions send them my way. 15 years exp but i cant figure out whats wrong with my own truck lol
