94 Explorer radio wiring help needed. | Ford Explorer Forums
wdmo1148
fl
I have a 94 Explorer 4 door, need to find out which wire is the ground on each of the 4 speakers connectors as I am installing a new JVC unit and speakers from Pioneer. Went on AllData but it did not indicate which color is the ground. It did not have a Radio it but all the wiring is all complete.Thanks for any Help.
I'm confused on what you are asking for. Are you looking for the ground (as in the ground for the headunit) or the negative speaker wires?
Why wouldnt you just buy a wiring harness?
Usually like 7$ at any car audio shop, probably 10$ at best buy, stores like that.
Makes it way easier. Make sure you dont forget the stock amp, you'll have to bypass that too.
You might as well buy an amp bypass kit for that, good luck figuring out the 40 wires on each side of the amp lol.
