cmnjn
- October 6, 2007
- Woodland, CA
- '94 EB Explorer
I have a 1994 EB 4x4 explorer about 130000 miles on it, bought it used at 90000 miles and have had no problems since other then the transmission fluid was getting sucked into the engine. Read up on that here so was getting ready to replace the vacuum modulator on the trans when this problem happened.
I have searched thoroughly on here and havent found much that relates to my problem, I hope someone can give me some things to check.
My Ex was running fine then all of a sudden just stalled while in gear. Put in park restarted with no problem then stalled again as soon as put in gear. Always starts up and always stalls when put in drive or reverse. The only way I was able to keep it from stalling was to throttle up & hold it there then put into drive (kind of like popping the clutch on a manual). Once i was moving it drove fine until I had to stop again. (I only did this to get it home since it cant be a good thing to do)
Any ideas?
Any ideas?
