Clusterpup
- April 6, 2009
- Miami, FL
- 02 Sport Trac 4x4
Yes it will fit
M16-A4 actually...
I don't think its too much on my truck...has anyone around her done an extra lift? I have pretty much the same as all of us with the 3" body 2" shackles and the torsion twist but i wanna go bigger I was looking at a 4 inch superlift made for the sport trac but idk if this would be good to do with the body lift installed does it sound like it could work? Or would it be too much?
The bumper is made up of a plastic front fascia and a steel reinforcement bar. I cut off most of the lower part of the front fascia off and lower part of the reinforcement bar. The metal bar you see is the upper piece of the reinforcement bar.john_rock did you have to relocate anything or modify anything to remove your bumper? i like the look, id like to try it
My rear bumper is the original bumper but with the sides cut off. And its painted.John do you have the rear plastic bumper on? or are you running the bumper reinforcement back there also?
