I have a 94 Ford Explorer that has developed a serious case of volume-itis... buttons no longer work. I am looking at replacing it with a Sony Xplod MEX-BT2700. According to my stereo specs I can use one of two harnesses:
Bypass factory amp
http://www.crutchfield.com/p_120705004/Receiver-Wire-Harness.html?tp=736
Utilize Factory Amp
http://www.crutchfield.com/p_120705510/Ford-Receiver-Wiring-Harness.html?tp=736
From what I understand (novice here) the installation on the second is much easier as you don't need to get into the rear door panel and mess with the amp. Is there a good reason not to use the factory amp? I am not looking at tricking out my car's entire sound system; just want a good working radio and bluetooth is too good to pass up
TIA
Bypass factory amp
Utilize Factory Amp
TIA
