shockwave1177
- February 18, 2008
- N.Y.
- 94 XLT
hey guys Im having a wiring problem, after reading all the bad things about the trailer (plug and play wiring), I am trying to hard wire the trailer lights. I cut the female adaptor off the trailer wiring harness from under the right side of my 94 explorer. The harness had one white wire (with a light test found to be the ground) witch I drilled a hole in the frame and cleaned and attached. It had 3 black wires that all had power depending on what signal or brake you had turned on. The last 3 were a yellow, brown and green wire. All 3 matched up to the color code wire on the universal wiring harness. I attached the 6 (3 from truck, 3 from wiring harness) same color wires to the proper power wire and a loud beeping out of what looks to be a fuse in the back left side of my explorer. I cant read the wiring biagram in my repair manuel, never learned how to read those.
To me (and Im buy no means a wiring expert) It sems that this connection should work with no touble. The beeping or buzzing is to loud to look past. If anyone has info. I would like to know what Im doin wrong. thanks:exp:
