94 mazda b4000 automatic transmission | Ford Explorer Forums
MONKEYSHINE47
wisconsin
94 mazda b4000
trans started slipping, blah blah. found problem to be the snap ring on the overdrive "cap" is halfway out of case. bleeding bad. I have dropped pan and removed all the bolts from the plate that the filter bolts to but it will not drop loose. I can move it a bit but it will not drop off. seems like its being held up in the center. What am i missing? do i need to be in a specific gear for it to drop? Help!
