mzcie
- November 20, 2004
- Sacramento, CA
- '94 Sport
'94 Explorer Sport 2WD, manual transmission. Check engine light won't go off and I must pass California smog test for license renewal. Three diagnostics with these results: 1st)Code 214 CID Circuit Failure - told to have engine diagnostic. 2nd)Engine diagnostic results: Code 121 TP sensor out of range; 214 CID Circuit Failure; Eratic Crank Sensor/TPsensor; Ignition Module; Defective ECM. Third time was told it was a defective ECM for sure. Yea, right.
I have replaced the following parts: oxygen sensors (2); TP sensor; PCV valve; crank sensor; ignition module (EDIS); and EEC-IV module (ECM).
Neg terminal replaced on battery, started engine and CHECK ENGINE light's still on. HELP!!! Do I need to leave the battery disconnected for a longer period of time? Should I drive around the block to assist the new BRAIN with recognizing the different auto?
Help. This old granny's outta money and patience.
Mz Cie - Sacramento, CA
