jake122288
- May 17, 2009
- Pleasantville, iowa
- 1994 4-door xlt 4x4
ok...so i tore the dist box open and was testing the wires via a test buld (its all i ahve...and im going to describe this the best i possibly can... the wires im describing and the positioning is with the dist box in its normal position....there is a red wire on top (cab side) which also branches to the red wire on top of the fuel pump relay (labeled 30 on the relay) ignition on or off this shows a ground....there is a white with black strip wire on the passenger side ( relay number 86) and its live with ingition on and nothing with ignition off (neither power or ground)the black and white striped wire on the drivers side is a ground with ignition on and off (relay number 85) and a yellow wire on the bottom side (closest to grill) (relay number 87) which gets no signal with ignition on or off.... (possibly because it keeps blowing the eec fuse) the yellow wire i know runs from the eec fuse...which has power at the fuse (without fuse in). i noticed the fuse was blown so i swapped it out and then when i hooked power back up and turned the ignition on the fuel pump relay would click repeatedly really loudly... does this mean the red wire is grounding out and thats what is causing my problem? is this the power wire from the eec? does anyone know where this wire come from? if it is from the eec could this mean my eec is bad which is causing the "short out" or is it more possible to be a bad spot in the wire? any help and info is greatly appreciated
