fender replacement is fairly straight forward. Just raise the hood, remove the bolts across the top of the fender (8mm if I remember right). From the underside remove the bolts that hold the fender to the fenderskirt...and your done. Might have to remove part of your pass. side light assembly depending on your truck...my 94 I didn't. I installed the Fiberglass fenders on mine. I suggest that when you get the new fender on...and the bolts in...you shut your hood and check for alignment (i.e. the gap running between your hood and fender) before tightening all the bolts back. Hope this helps!!!
