95-01 your thoughts | Page 3 | Ford Explorer Forums
95-01 your thoughts
The AWD has a 50-50 ratio for the transfer differential case for front and back driving capability. the 4WD has a 2.48:1 ratio for the transfer case, or 40:60 ratio, 40 for the front and 60 for the back, this is power distribution to the wheels, and the 4WD system is on demand, which means you can activated it whenever you feel like it. The AWD system, you have no choice it is always activated.
Incorrect on both counts.
From the 98 service manual for the AWD case:
The viscous clutch is a non-repairable, torque distribution device. The internal construction of the viscous clutch consists of alternating plates that are connected to the front and rear outputs of the transfer case. The viscous clutch is filled with a high viscosity fluid which flows through slots in the plates. The resistance to shear causes the plates to transmit torque at the needed ratio. The ratio that torque is transmitted at is approximately 35% front and 65% rear.
and for the
Control-Trac automatic 4wd case:
C-Trac Function
The C-Trac transfer case transmits torque to the front wheels through an electromechanical clutch assembly. In the Auto mode, while at rest and under cruising conditions, the Generic Electronic Module (GEM) activates the transfer case clutch at a minimum level. This allows for the slight difference between the front and rear driveshafts which occurs normally when negotiating a corner on dry pavement. Under any of the following conditions, the GEM will increase the torque sent through the clutch to the front wheels in order to prevent or control slip.
l Slip is detected (by monitoring the Hall Effect Sensors in the transfer case)
l Heavy acceleration (by using the throttle position signal from the EEC)
l Very light or zero throttle at speeds above 64 km/h (40 mph) (using the throttle position signal from the EEC)
Range Function
In the 4WD Low Range, the transfer case electromechanical clutch locks the front and rear driveshafts for maximum 4WD traction. The transfer case motor also rotates the shift cam to move the reduction fork to the 4WD low range position. This low range shift is accomplished through a planetary gear set which changes the torque to the driveshaft from 1:1 to 2.48:1 ratio.
In the 4WD High Range, the GEM locks the front and the rear driveshafts for maximum 4WD traction. This position is not meant for use on dry or merely wet pavement. It is intended for off-road or severe winter weather use only.
You have to read between the lines there, but you get between a 0/100 torque split and a 50/50 torque split with the control trac function. The 2.48:1 gear ratio mentioned is the gear reduction for low range (which yes, you only got with the two-speed transfer case attached to the V-6).
I did not have my manuel handy like ^ but I was going to say that I thought the AWD would be a uneven amount of torque other wise all these people doing the 4406 transfer swap are only doing it for the mileage and not for the 4x4 capabilty that a 4wd system brings to them...
oh that is correct, my mistake, I was reading the wrong information, haha, sorry i was reading the infromation for a mercedes AWD and mixed it up with the information on had for the explorer
OK back to our questions I have had a gen 1 4.0 L OHV and now have a 99 SOHC 4.0 L and the SOHC is a better choice of the 2 IMO it gets way better MPG's and better power (again IMO)...
As for first mods and staying in mind of the collage budget.
1/ K&N air filter (or something like it)
2/ Exaust CAT back (breath in breath out)...
I'm also going 3" body lift and 31" (for now) tires (soon to be 33")
Oh and don't forget the sat radio and dvd in the back for my kids...lol...
